outdoor reset
Glenn Sossin_2
Member Posts: 592
Tekmar 256 - Inexpensive, relatively simple to wire. See attachment.
An even easier way is the use Taco EXP relay with the PC700. It is essentially a 256 made to plug into the relay - wire up the sensors and program. See attachment
outdoor reset
looking for simple outdoor reset control which uses thermisters for sensors0 -
Tekmar
has them simple enough or more complicated if you prefer. Very good sensors, very accurate 10 kOhm thermistors."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0
- 87K THE MAIN WALL
- 57 Biomass
- 116 Chimneys & Flues
- 5.7K Gas Heating
- 109 Geothermal
- 70 Pipe Deterioration
- 985 Plumbing
- 6.3K Radiant Heating
- 389 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
- 48 Job Opportunities
