Dave Yates - DF
Brad White
Brad White Member Posts: 2,399
and meant to post... Good of you to recognize it, Dan.
Dave- great article, one that should find it's way as a handy reference in re-prints, maybe more permanent status if Taunton ever does a more mechanical book culled from excellent articles.
Congratulations on a job well-done!
"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad
  • Dan Foley
    Dan Foley Member Posts: 1,268
    Yates
    Great article by PAH in the current Fine Homebuilding - Kitchens & Baths issue. See if this link works:
    http://www.taunton.com/finehomebuilding/how-to/articles/choosing-water-heaters-tank-and-tankless-options.aspx?ac=ts&ra=fp
    Way to raise the bar, Dave, and educate the masses!
    I missed you at the Solar Decathlon this weekend. We are heading back tomorrow for one final look. Go Maryland!
    - DF
  • JJ_4
    JJ_4 Member Posts: 146
    I read it last weekend....
    and didn't put the authors name together with the Wall. Very good from a homeowners perspective. I'll soon be up against that decision as I have a 11 year old cheapy tank WH. Thanks.
    hot_rod Member Posts: 26,629
    Well written and
    nicely illustrated. No mention of solar preheat? But your picture looks to be one with a solar tube in hand :)
    hot rod
  • Thanks!
    That was fun to write and FHB did a great job with the graphic illustrations. It's generated lots of reader e-mails. Thanks for the high praise, which means more coming from my peers.
    Solar is in the works(G).
    They're striving to create an interactive water heater sizing and life-cycle cost guide on their web site using my Excell spread sheets. It's a work in progress, but nearing completion. Solar will be included if they use all my info on life-cycle costing.
