Leaking Nipples
Jamie Hall
Member Posts: 26,847
to the various chaps who encouraged me to try using the red RTV to seal between radiator sections when faced with badly eroded push nipples -- it worked. Very nicely.
However...
It somewhat offends my sense of 'rightness' (yeah, I know, if it works, go with it).
So the next question is: does anyone know where to get new push nipples for radiators? These are the usual very slightly double tapered puppies, inch and 3/4 diameter by inch and an eighth long. Sufficiently badly corroded/eroded/trashed/whatever so that miking them to get the tape would be ... um ... difficult.
Suggestions?
However...
Suggestions?
Go here, Jamie-
http://www.heatinghelp.com/newsletter.cfm?Id=20
I think Oneida County Boiler Works is about the only source these days.
I was afraid you'd say that... I'll try them. Thanks!Br. Jamie, osb
leaky nipple cure
Take oxytocin (Pitocin). Works well on new mothers..
Sorry, just had to.0 -
Is that for ...
hot water or steam? kpc
Wholesalers
I have a couple of OLD wholesalers who MAY have something on the shelf.We may even have something out in Westfield from the old Smith Radiator/Reed radiator days. We may need to grind off the dust, though...
I will inquire.0 -
anyone ?
Anyone out there know where to get 1.5 inches right/left threades radiator nipples?0 -
steam -- vapour system.
oy! If you find a few -- jchnhtfd@att.netBr. Jamie, osb
Excellent!!
Someone HAD to!
Mark H
And
While he said what many only thought, he did it without using any contractions...
I am so bad...0 -
push nipples
I would suggest you go to your local {good} machinist and have them fabricated out of quality steel. We have an excellent machine shop up here called Prichard Engineering and they made some for us that worked very well.
Good Luck and all the best
Jack Ennis Martin0
- 167 Indoor-Air Quality
