If our community has helped you, please consider making a contribution to support this website.  Thanks!
Cast radiator steam valve hole stripped
                    John Shea
                    Member Posts: 247
                    you'll probably want to drill and tap for 1/4" NPT. Then use a 1/4" to 1/8" bushing.
            Cast Iron Steam Radiator Valve Hole Stripped
What is the most simple way to re-thread the hole into which the radiator steam valve screws on a cast Iron radiator? I believe the hole opening is 1/8" in diameter.0 -
            1/8\" Pipe tap
You need a 1/8" pipe tap. Turn in the tap1/4 turn clock wise in , then 1/8 turn counter clock out...Continue until threads are redone. This action will prevent the tap from binding ,thus breaking which would suck.....0
 - 87.2K THE MAIN WALL
 - 118 Chimneys & Flues
 - 113 Geothermal
 - 164 Indoor-Air Quality
 - 73 Pipe Deterioration
 - 6.4K Radiant Heating
 - 393 Solar
 - 15.5K Strictly Steam
