cast iron radiators
JackEnnisMartin
Member Posts: 70
Hello
One of the young chaps in the shop asked a question I could not answer{ happens every week} in the old rads were the push nipples cast or steel. I do not know the rads I took out of Eatons thirty years ago appeared to have steel nipples and they were from the beginning of the twentith century. I would like to have some imoformation when you have the time.
Thanks for your help, all the best
Jack Ennis Martin
Jack Ennis Martin
Cast Iron Radiators
Cast iron, when polished or ground, will have an appearance not unlike steel, especially if the CI is of a fine grain type.
One sure way to tell: Smack it with a hammer.0 -
Am almost positive that they're steel. I've knocked out many using a screwdriver and they dent--they don't break.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 129 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 58 Water Quality
- 48 Industry Classes
- 15 Recall Announcements
