Steam radiator parts needed
Phillip Biston
Member Posts: 42
I have an old steam radiator that I took out to sandblast and refinish, in moving the radiator I damaged (putting it mildly) the 1 1/2" thread nipple that screws into the radiator and seats into the valve. The collar nut that screws onto the valve is 2" I would like to know if these parts are still around, nobody here in northeast MO. seems to have any.
Thanks, Phillip
Thanks, Phillip
rad valve.
you will probably need to replace the valve and it's union.
Lots of manufacturers make these. Mepco, Watts to name a few.
http://www.mepcollc.com/radvalve.htm#Mepco2
JimThere was an error rendering this rich post.
- 167 Indoor-Air Quality
