I am concerned about using a low volume boiler such a a Biasi wi
called the Solaia. They recommend using either a thermal bypass valve or a primary-secondary system. We've done it both ways and I like P/S better.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Ken Brown
    Ken Brown Member Posts: 3
    low volume boiler used with old gravity piping/big radiators
    I am concerned about using a low volume boiler such as a Biasi with an old heat system that was formerly a gravity system. It has 2-inch mains and returns and many big Cast iron radiators. What is your thinking on this? Thanks. Ken
  • Perry_2
    Perry_2 Member Posts: 380
    You need
    something like a Vitodens Low Loss Header to connect the two. Given the old gravity system - perhaps a larger one than your normal system flows would indicate.
    You could of course build something like it if you did not need a good temperature indication of the Mix temp.
    Perry
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,584
    Reset
    boiler temp only to safe operating point,then reset system supply temp as low as you want a with motorized mixing valve. This works great with high mass radiation
