I am concerned about using a low volume boiler such a a Biasi wi
Steamhead (in transit)
Member Posts: 6,688
called the Solaia. They recommend using either a thermal bypass valve or a primary-secondary system. We've done it both ways and I like P/S better.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
low volume boiler used with old gravity piping/big radiators
I am concerned about using a low volume boiler such as a Biasi with an old heat system that was formerly a gravity system. It has 2-inch mains and returns and many big Cast iron radiators. What is your thinking on this? Thanks. Ken0 -
You need
something like a Vitodens Low Loss Header to connect the two. Given the old gravity system - perhaps a larger one than your normal system flows would indicate.
You could of course build something like it if you did not need a good temperature indication of the Mix temp.
Perry0 -
Reset
boiler temp only to safe operating point,then reset system supply temp as low as you want a with motorized mixing valve. This works great with high mass radiation
- 120 Geothermal
