8 inch by 13 inch
There is a B&G series 100 pump on it at the back, of course, pointing toward the PONPC.
There are few left around, not too many. I'd like more of them.
  • Jeff Lawrence_25
    Jeff Lawrence_25 Member Posts: 746
    Tile lined Chimney, 27 feet
    From breeching to top. The chimney is all 'inside,' no exterior surface.
    I'm replacing this 56 year old, natural gas guzzling monster with either a cast iron boiler (~130K) or a condensing boiler. If we go with the condensing boiler, we'll put the PVC for the vent in the chimney.
    Do I have to line the chimney if we go with the cast iron boiler?
  • Jeff Lawrence_25
    Full Frontal shot
    In all it's glory.
  • Jeff Lawrence_25
    What a conversion!
    origonal was possibly oil, looking at the lines on the floor of the crawlspace.
  • Jeff Lawrence_25
  • Jeff Lawrence_25
    Love the wiring.
    Ain't it grand?
  • Jeff Lawrence_25
    And
    A strap on, no less!
  • Jeff
    Is that a gravity hot water system ? If it is , this must be some kinda Karmic moment . We started an American Standard gravity boiler replacement today . I'll post some pics tomorrow .
    Do you see these beasts down south alot ?
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    Jeff,
    Strap-ons were standard equipment back in the day ! It was much easier to cast sections without tappings...don't you know.
    Personally, My thought is...if you're going to use the chimney with a gas fired appliance, LINE IT, and only use stainless for the liner.
    I'll see if I can dig up the picture of the aluminum flue liner that was installed by a "less than competant" installer.My chimney guy saved this because he knew he would be sseing me the next day. By the way, I was told that this was less than 1 year old!.. Go for it...but do it right. Chris
  • Jeff Lawrence_24
    Jeff Lawrence_24 Member Posts: 593
    I'm not lining it.
    A gent that works with me is actually doing the lining. I mentioned the SS vs AL liners and he looked at me like a deer in the headlights, "Alumimum? No Way! Stainless steel is the only way!"
    Can beat that, can you?
    This gent will be doing the high voltage wiring also. Go figure, a chimney sweep that's also an electrician....
  • S Ebels
    S Ebels Member Posts: 2,322
    Aluminum liners
    The only good use for them is venting an electric clothes dryer. They should be banned for venting heating appliances of any type.
