Radiant Heat contractor in Santa Barbara, CA 93110
Cheryl_4
Cheryl_4 Member Posts: 1
I want to install radiant heating in my house in Santa Barbara, CA and am looking for a contractor. The floors are hardwood and there is a subfloor. I have this type of heating in my house in Pleasanton and have a Viesmann boiler. Any suggestions? Thanks. Cheryl
  • Timco
    Timco Member Posts: 3,040
    Did you look under resources at the top of the page? Dave Forbes ( California Radiant ) is listed there, if I recall correctly...not sure of his area though..
    Tim
    Just a guy running some pipes.
  • Fred Harwood_2
    Fred Harwood_2 Member Posts: 196
    radiant
    Perhaps nowhere else on the planet than in SB can radiant work so well. If only the wildfires, and the mindset fostering them, would stop.
    Get a competent contractor, and your comfort should be assured, absent wildfires.
  • Tom Hopkins
    Tom Hopkins Member Posts: 554
    Radiant Heat Contractor
    We are located in Southern California (Santa Monica) and have jobs in Montecito/Santa Barbara and as far north as Pismo Beach.
    We are very experienced Viessmann installers as well. I recommend them on every job.
    We'd be happy to take a look at your project.
    Regards,
    Jacob Gooze
    ACME Environmental Group
    3200 Airport Avenue #18
    Santa Monica, CA 90405
    (310)397-2199
    info@acmegreen.com
    http://www.acmegreen.com
  • Tim from Timco
    Hi- I'm working with Jerry Sullivan in Los Angeles and he said a guy named Tim from Timco in Santa Barbara was the best he knew. The phone # for Timco in SB is disconnected. If you are the same Tim how can we get hold of you.
    Thanks Geoff DeWan Fort hill Construction
