Radiant Heat contractor in Santa Barbara, CA 93110
Cheryl_4
Member Posts: 1
I want to install radiant heating in my house in Santa Barbara, CA and am looking for a contractor. The floors are hardwood and there is a subfloor. I have this type of heating in my house in Pleasanton and have a Viesmann boiler. Any suggestions? Thanks. Cheryl
Did you look under resources at the top of the page? Dave Forbes ( California Radiant ) is listed there, if I recall correctly...not sure of his area though..
TimJust a guy running some pipes.0 -
radiant
Perhaps nowhere else on the planet than in SB can radiant work so well. If only the wildfires, and the mindset fostering them, would stop.
Get a competent contractor, and your comfort should be assured, absent wildfires.0 -
Radiant Heat Contractor
We are located in Southern California (Santa Monica) and have jobs in Montecito/Santa Barbara and as far north as Pismo Beach.
We are very experienced Viessmann installers as well. I recommend them on every job.
We'd be happy to take a look at your project.
Regards,
Jacob Gooze
ACME Environmental Group
3200 Airport Avenue #18
Santa Monica, CA 90405
(310)397-2199
info@acmegreen.com
http://www.acmegreen.com0 -
Tim from Timco
Hi- I'm working with Jerry Sullivan in Los Angeles and he said a guy named Tim from Timco in Santa Barbara was the best he knew. The phone # for Timco in SB is disconnected. If you are the same Tim how can we get hold of you.
Thanks Geoff DeWan Fort hill Construction
- 86.9K THE MAIN WALL
- 57 Biomass
- 110 Chimneys & Flues
- 5.7K Gas Heating
- 105 Geothermal
- 70 Pipe Deterioration
- 982 Plumbing
- 6.3K Radiant Heating
- 387 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
