Hanging 5/8 pex al pex
ralman
ralman Member Posts: 231
Somehow I completely missed that important fact. Any idea what I could use that will handle higher temps and hold 5/8 pex al pex?
  • ralman
    What hangers work best for 5/8 pex al pex?
    Running baseboard to baseboard under floor joists, what hangers work best for 5/8 pex al pex? I did not see 5/8 pick up talons at Sioux Chief website. Their 3/4 pick up talons leave the 5/8 pex al pex loose in the hanger.
  • Brad White
    Brad White Member Posts: 2,399
    I used the 3/4
    Talons (the kind that are both 1/2" and 3/4" combination sizes) without a problem. Good snug fit. The 5/8" Kitec that I used at least, was 0.875" OD, same as 3/4" copper tube.
    "If you do not know the answer, say, "I do not know the answer", and you will be correct!"
    -Ernie White, my Dad
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    the combos...
    sort of work but not real well...I wish they would come out w/ 5/8 omega clamps...
  • Caution Will Smith...DANGER, DANGER
    (said in Robot's voice in Lost in Space...)
    The Sioux Chief talon suspension clamps and other offerings are only good to 160 degrees F, and sharp building inspectors know this...
    http://www.siouxchief.com/Frm_MS.cfm
    ME
  • Darin Cook_5
    Darin Cook_5 Member Posts: 298
    I use
    Sioux Chief Touchdown clamps. They have one that goes up to 1 1/8" OD pipe. They can hold pex, pap, copper, wire, and anything else you can fit in them. They are plastic( no expansion noise) with two zip-tie ends which you can take apart with a small screwdriver. They run about 30 cents apiece, cheap!! It is my all around hanger to keep on the truck. They make the same style for bigger pipe which is nice for a/c linesets also.
    Darin
  • Brad White
    Robot
    (Hardly, that, Mark!)
    Good to know. Fortunately, I am only running 140F maximum but a fair warning. I did not see that on the package.
    Thanks!
