Hanging 5/8 pex al pex
ralman
Member Posts: 231
Somehow I completely missed that important fact. Any idea what I could use that will handle higher temps and hold 5/8 pex al pex?
What hangers work best for 5/8 pex al pex?
Running baseboard to baseboard under floor joists, what hangers work best for 5/8 pex al pex? I did not see 5/8 pick up talons at Sioux Chief website. Their 3/4 pick up talons leave the 5/8 pex al pex loose in the hanger.0 -
I used the 3/4
Talons (the kind that are both 1/2" and 3/4" combination sizes) without a problem. Good snug fit. The 5/8" Kitec that I used at least, was 0.875" OD, same as 3/4" copper tube."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
the combos...
sort of work but not real well...I wish they would come out w/ 5/8 omega clamps...
Caution Will Smith...DANGER, DANGER
(said in Robot's voice in Lost in Space...)
The Sioux Chief talon suspension clamps and other offerings are only good to 160 degrees F, and sharp building inspectors know this...
http://www.siouxchief.com/Frm_MS.cfm
ME0 -
I use
Sioux Chief Touchdown clamps. They have one that goes up to 1 1/8" OD pipe. They can hold pex, pap, copper, wire, and anything else you can fit in them. They are plastic( no expansion noise) with two zip-tie ends which you can take apart with a small screwdriver. They run about 30 cents apiece, cheap!! It is my all around hanger to keep on the truck. They make the same style for bigger pipe which is nice for a/c linesets also.
Darin
Robot
(Hardly, that, Mark!)
Good to know. Fortunately, I am only running 140F maximum but a fair warning. I did not see that on the package.
Thanks!"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
