Sunrad Radiators
Bryan_16
Bryan_16 Member Posts: 262
know the water volume per section of an ARCO Sunrad 5" deep x 20" tall rad. Trying to figure the water volume of a system to install anti-freeze.
  • Big Ed_4
    Big Ed_4 Member Posts: 3,363
    No I don't ........but courious
    I just keep adding and mixing until I reach the right mix and charge per gallon. I would think it would be a guess any way if I tried to figure the whole system. You could drain and measure to get a correct number but then you would have to purge the whole system .
    J
  • Bryan_16
    little late
    It is all drained at this point awaiting a new boiler. I was just trying to figure how much anti-freeze to order.
  • gerry_6
    gerry_6 Member Posts: 33
    Antifreeze why?
    Its not cheap, is it for freeze protection? If not but you want corrosion inhibitors I like Rhomar.
  • Bryan_16
    freeze
    protection. Homeowner requets it.
