can anyone do room by room heat loss calc in Los Gatos, Ca?
Brad White
Member Posts: 2,399
the Heat Loss Calcs link under the "Resources" tab above. It is easy and gets you invested in the process. You can always run the results by us for a sanity check.
EDIT: I have USAF weather data for the following California (KAH-li-FOR-NI-AH) locations. Which is closest to you or best represents your climate? I can post it in PDF format.
Brad
ALAMEDA (FORMERLY ALAMEDA NAS),ARCATA/EUREKA, BAKERSFIELD/MEADOWS, BARSTOW-DAGGETT,BEALE AFB/MARYSVILE,
BLUE CANYON,CAMP PENDLETON MCB (FORMERLY MCAS),
CRESCENT CITY, EDWARDS AFB,FRESNO,IMPERIAL, LEMOORE, NAS/REEVES, LONG BEACH, LONG BEACH (AIRPORT), LOS ANGELES,
MARCH AFB, MARINA MUNICIPAL/FRITZSCHE (FORMERLY FORT ORD-FRITZSCHE AIRFIELD, MCCLELLAN AFB,MERCED (FORMERLY CASTLE AFB), MIRAMAR NAS, MONTAGUE/SISKIYOU, MONTEREY PENINSULA, MOUNTAIN VIEW/MOFFETT FEDERAL AIRFIELD (FORMERLY MOFFETT NAS), NORTH ISLAND NAS, OAKLAND, ONTARIO, PASO ROBLES, PIEDRAS/BLANCAS POINT, PT MUGU, RED BLUFF,
SACRAMENTO/EXECUTIVE, SACRAMENTO/MATHER AIRPORT (FORMERLY MATHER FIELD), SAN BERNADINO (FORMERLY NORTON AFB), SAN CLEMENTE, SAN DIEGO/LINDBERG, SAN FRANCISCO, SAN JOSE,
SANDBURG, SANTA BARBARA, STOCKTON, TRAVIS AFB/FAIRFIELD, TUSTIN, VANDENBERG AFB, VICTORVILLE (FORMERLY GEORGE AFB)
Brad
"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad
I'm looking for someone who is skilled at room by room heat loss calculation to determine optimal heating solution.
Thanks.0 -
Your best bet
Might be California Hydronics in Hayward or JTG Associates in Berkeley. If not, ask for a referal and they might direct you to someone that can help.
I don't recall the ph#s, but I bet Mr. Google would.
thank you, Rob.
Brad - I think Mtn View/Moffet is closest (San Jose is physically closer but my elevation is higher, so weather-wise I'm probably more like Mtn View/Moffet or Monterrey...
Cathy0 -
Here is the weather data
For Mountain View and Monterey if it helps you.
Typically, we would use the 99% or 99.6% occurrence data (40 and 37 degrees respectively for Monterey for example). You are fortunate to live in such a mild climate, but you know that...."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0
- 87K THE MAIN WALL
- 112 Chimneys & Flues
- 106 Geothermal
- 979 Plumbing
- 387 Solar
