bathroom radiator
bigwilly104
Member Posts: 50
unless he wigs out every mourning its just steam.
Bathroom radiator
I Have a customer with Buderus modes 11 radiator that is 12" tall 16" wide 21/2" deep. It has been replaced twice in ten years due to rusting. Lots of bathroom moisture. This size seems hard to find. Buderus discontinued the 16" wide models.
I am more interested in finding something that can handle the moisture.0 -
Willy
your right, the 16"'s only come in the model 22.
When you say moisture, is that a euphemism?
Is this next to the toilet ??
I have a lot of Buderus Panels in bathrooms that are fine.
Scott
Try a better exhaust fan
Sounds like the problem is more an exhaust problem more than anything. Consider putting in a stronger fan or checking the venting. It might be "dryer duct" with too long of a run.
That and continuous circulation
If continuous circulation is used without warm weather shut-down, cool water can be circulated. Not just cool as we think of it but below the dew-point of the bathroom during a shower.
As Justin said, the fan or venting may not be up to the task. If the fan is on and the door is closed, you should feel a definite draft under the door crack.
"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0
- 62 Biomass
