Aqua pex
Joe_76
Member Posts: 34
Has anyone seen AquaPex used for radiant. Has anyone seen any problems with this stuff? I was asked to bid on a boiler hook up that had AquaPex used to feed Heat Handlers. Nice color coding.
yes...but
in each case it either had an HX or every part in the system was non-ferrous....it has no oxygen barrier.kpc
Thanks for the reply Kevin. I had not seen anyone use it so I was just wondering. I use Kitec only, just because I like the Al O2 barrier. I think that I will pass on the job. Besides the pipe I have a really bad feeling about this one. The you touch it you own it saying makes me realize that even in a small town a guy could get in trouble.0 -
Joe , if they paid you for an estimate....
why not stop in and open the bottom drain on the boiler into a white bucket for them?0
- 167 Indoor-Air Quality
