Aqua pex
Joe_76
Joe_76 Member Posts: 34
Has anyone seen AquaPex used for radiant. Has anyone seen any problems with this stuff? I was asked to bid on a boiler hook up that had AquaPex used to feed Heat Handlers. Nice color coding.
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    yes...but
    in each case it either had an HX or every part in the system was non-ferrous....it has no oxygen barrier.kpc
  • Joe_76
    Thanks for the reply Kevin. I had not seen anyone use it so I was just wondering. I use Kitec only, just because I like the Al O2 barrier. I think that I will pass on the job. Besides the pipe I have a really bad feeling about this one. The you touch it you own it saying makes me realize that even in a small town a guy could get in trouble.
  • Weezbo
    Weezbo Member Posts: 6,231
    Joe , if they paid you for an estimate....
    why not stop in and open the bottom drain on the boiler into a white bucket for them?
