oil fired boiler repair
Mark Hunt
Member Posts: 4,908
target wall. It prevents the oil flame from hitting the back of the boiler. Without it the flame impinges on the boiler wall and causes that spot to get much hotter than the rest of the boiler resulting in thermal stress. Shortens the life of the boiler. Not to mention what happens to the water that comes in contact with the "hot spot".
Long story short, you need it.
Mark H
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=238&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Mark H
oil fired boiler service
i just got a home inspection done and the service guy said that some kind of board needs to be replaced in the boiler cause its cracked. he said that was causing the hot surface behind the boiler. he also said that the part costs around 50 bucks. does anyone know what he is talking about. thanks0 -
Yes
Probably called a "target wall" in the combustion chamber. Kao-wool board is a common name. It is high heat resistant and a spun glass ceramic or cera-felt type of thing. Very common.0 -
And if it
happens to be a dry base boiler *(no water behind that target wall) you need to address the issue ASAP, if it burns through the back boiler wall it is a CO issue and fire hazzard.0 -
and if it IS a dry base
you just might want to kick it to the curb...
a wet pack costs money as does the labour...puting a new complete base and gaskets after removing all the skins you have removed the skins right? you should ...that way you can see just what else may have been happening while the combustion processes changed over the years...0 -
thats it
thats what he called it a target board. is it hard to install.0 -
target board
It depends ...0 -
depends on what. the boiler is very accessbile. it is a burnham boiler if that helps0 -
Which model Burnham
is it?
The access
The accessability of the boiler is only part of the equation. Getting it apart is the other part. If the bolts are rusted bad they could break which involves drilling and tapping threads. Once they come out the whole boiler needs to be cleaned if it has not been done recently. Then install the new kit (the target wall comes in a chamber kit). Then once the unit is reassembled it needs to be checked and adjusted with combustion testing equipment. The job can be from two to more hours.
Leo0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 106 Geothermal
- 982 Plumbing
- 388 Solar
