kitec pipe
I liked the PAP for retrofit water pipe jobs in older houses.<BR><BR>Dave
kitec pipe
Got the info from my kitec rep that there stopping production of pex-al-pex for domestic water use. Will only make pex for dom. use. But will stil make orange p-a-p for heating only.0 -
Is this a Kitec only problem?
More details please!0 -
Look for black spotting or staining "inside" the pipe. Then look for bulges in the pipe. Especially on recirc lines.0 -
kitec pipe
I have replaced alot of this type of pap up here in seattle. Yes, it starts to develop black spots and then bulge and start to leak. I have see this pipe in 168 unit complex up here and I let the maintance know that it has black spots all over it. They connect to hydro air units in the condos from the GSW waterheaters. If you cut the pipe at the black spot the aluminum is all white kind of like salt on it.0 -
PlumbBetter XPA
Gentlemen,
Sorry to report that the real reason is not nearly as colorful as the previous posts but it is simply economics. We had a premium product in a commodity business and our costs caught up with our returns.
This is a phase-out situation and all pipe manufactured up to December 01 and sold thereafter is fully certified and waranteed.
IPEX will now be able to fully focus on our more competitive PlumbBetter PEX pipe and fittings in plumbing, and will continue to aggressively pursue both WarmRite PEX-AL-PEX and our new 5 layer barrier PEX in heating.
Please don't hesitate to call us with further questions.0 -
supposedly cost. contractors didn't want to spend the extra pennies for pap over pex.0 -
Just spend big bucks on fittings and tools to use your product. and now what???? Can we get refund on fittings as I will be changing brands to get pex al pex for domestic use?? Not a happy camper with stock I can no longer use.0 -
Please call your local rep. We have a lot of products that we wish to sell you for a long time so our preference is to find a way to keep you a happy camper.0 -
If you want happy campers why didn't you take care of the problems out west before they sued you?0 -
Was this specifically Kitec?0 -
Yes0 -
I asked Aaron a question. If you presume to answer for Aaron then you need to give your credentials for doing so. Otherwise I will wait for Aaron to answer me.0 -
Just go here. why do i need credentials to prove it when its all over the web.
http://www.plumbingdefect.com/index.html
Richard,
If your question was directed to Aaron, you could have posted it in a better place and actually addressed him. Your question was asked in general and not to anyone specific.
Take it easy.0 -
Hey, I replied to Aaron's post. You jumped the gun and assumed it was a general question. Chill and all is cool OK?0 -
You answered a question specifically directed to Aaron. If you presume to speak for Aaron then you need to have some credentials why you can answer with knowledge about the specific pipe and the specific job he referenced. That's all. But hey, relax. It's all cool man.0 -
Chuck
Will the pex be warrantied when used as a recirc line?
Do we have to wait for current pipe to fail before we can claim warranty, or will signs of deterioration be enough?0 -
Richard Miller
Hello Richard, Yes this was Kitec PAP pipe.
Kitec
Didn't anybody read the install limitations on water quality before they installed kitec?0 -
Nothing wrong with our water.0 -
Thanks Aaron.
And this was a tubing failure, not a fitting system failure?0 -
are you stillgoing to be makink p-a-p for domestic water in rolls? If not, you can't make me happy0 -
kitec
This problem looks like a water quality problem to me.Thats why the plastic fittings came out.Can blame this on the manufacture.0 -
EXFiXto6
Can or can't?
And how is the water quality affecting Kitec?
Is there any Kitec failures say in NM or CO?0
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
