Mr. Pex
ALH_4
ALH_4 Member Posts: 1,790
That's good to hear, because it was a major problem. Many times I could easily push the tube into Thermofin with one finger. Sure made a few jobs real headaches after the fact.
  • Dobber
    Dobber Member Posts: 91
    Mr. Pex
    I've been using Mr. Pex a lot this year and am impressed by the product,especially the pipe.Is anyone else using it and what are your thoughts on the subject.
    Thanks
    Dobber
  • ALH_4
    aka Tomas Lenman
    It's good stuff. Had a little trouble with it being oval from coiling toward the center of the roll. That was only an issue when snapping it into extruded aluminum plates. From what I could tell, the oval would return to a circular pipe with time.
    Otherwise it's good Pex-a at a good price from one of the originators of pex tubing. I'm not quite as sure about the Safelink manifolds. Too many O-rings just waiting to leak, particularly with glycol.
  • Dobber
    Oval
    I've laid around 25,000'so far with no evidence of the pipe being out of shape.If there was a problem I think they may have addressed them.Heatlink had the same problem a couple of years ago.
    As far as the o-rings are concerned don't most manufactures use o-rings in their manifolds? Does the type of glycol make a difference?
    Thanks
    Dobber
  • scott markle_2
    scott markle_2 Member Posts: 611
    Marketing
    I'v got to say the name makes me think of a cheep liqueur brand. For what it cost to set up a pipe plant they should probably consider some professional branding help. Is all pex created equal? , Is electron beam pex better than engel method ?, is one processes environmentally friendlier than others? Do you get what you pay for? or is pex just pex?
    Personally I like the idea of a particle accelerator being involved, just cause it sound cool, but I'm a slave to marketing.
  • Andrew Hagen_2
    Andrew Hagen_2 Member Posts: 236
    oval
    It was only ovalled a few thousandths of an inch, but that makes a difference with plates.
  • that problem was fixed, as far as I know.
  • Seriously. we use Mr. Pex, but I wince every time we say the name.
  • ALH_4
    mr pex and plates
    As I remember, they added a layer of PE on the outside of the tube to reduce the "stickiness" of the EVOH barrier? I dont know if the ovalling has been addressed. There were times that the pex would literally fall out of the plates, a problem that never occurred with other pex.
  • Yes, and that addressed the ovalling too I believe.. we've never seen a case of fall out.
