panel rads
Dobber
Member Posts: 91
I am currently doing a log home and had quoted Buderus panel rads.Unfortunately I did not realize that I need a rad that the supply-return has to come off the end because of the t&g floor under rads.Any suggestions would be appreciated.
Thanks
Dobber
Thanks
Dobber
All panel rads...
...have a supply and return from the lower right hand corner. We've installed many rads over a T&G floor. This is usually not an issue. They can also be roughed in from the wall, which takes a little more time and materials.
Runtal UF series baseboard can be piped from the ends.
But one manufacturer
maybe it was Myson, that has center connections, internally piped for proper circuiting.
Runtal can give you what you need. Some models allow piping bottom or end and you just plug the unused tappings."If you do not know the answer, say, "I do not know the answer", and you will be correct!"
-Ernie White, my Dad0 -
Dianorm
I think Dianorm has the center connections. Not sure about Myson.0 -
Found it....
Myson does as well. I have to wonder if these are made by one company and marketed OEM to other companies? Too similar but at least it looks like we have choices.
http://www.mysoninc.com/Pages/Radiators/T6.html"If you do not know the answer, say, "I do not know the answer", and you will be correct!"
Rads
There is so much "re-branding" out there that I cannot keep track. (Why do I try? ;-)) I seem to remember something about someone (perhaps Myson) manufacturing radiators for Dianorm.0
- 87.7K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
