panel rads
Dobber
Dobber Member Posts: 91
I am currently doing a log home and had quoted Buderus panel rads.Unfortunately I did not realize that I need a rad that the supply-return has to come off the end because of the t&g floor under rads.Any suggestions would be appreciated.
Dobber
  • Paul Pollets
    Paul Pollets Member Posts: 3,672
    All panel rads...
    ...have a supply and return from the lower right hand corner. We've installed many rads over a T&G floor. This is usually not an issue. They can also be roughed in from the wall, which takes a little more time and materials.
    Runtal UF series baseboard can be piped from the ends.
  • Brad White
    Brad White Member Posts: 2,399
    But one manufacturer
    maybe it was Myson, that has center connections, internally piped for proper circuiting.
    Runtal can give you what you need. Some models allow piping bottom or end and you just plug the unused tappings.
    -Ernie White, my Dad
  • ALH_4
    ALH_4 Member Posts: 1,790
    Dianorm
    I think Dianorm has the center connections. Not sure about Myson.
  • Brad White
    Found it....
    Myson does as well. I have to wonder if these are made by one company and marketed OEM to other companies? Too similar but at least it looks like we have choices.
    http://www.mysoninc.com/Pages/Radiators/T6.html
  • ALH_4
    Rads
    There is so much "re-branding" out there that I cannot keep track. (Why do I try? ;-)) I seem to remember something about someone (perhaps Myson) manufacturing radiators for Dianorm.
