Radiant Project Pictures
ChrisCT
Member Posts: 8
Thanks for the info. I know a plumbing supply house I can check with for the good stuff.
Hi, I am a homeowner currently working on a radiant heating retro-fit. Since I found a lot of info on this site and from NRT Rob who posts here, I thought I'd post a link to some pictures of the project. The web site is www.lxdragon.com/radiant1.htm
Thanks! And thanks to Dan for letting me link to this site.
Chris.0 -
DIY project
Wow...congratulations on a nice looking job. I hate to say this but it's true......a lot of guys doing this for a living could take some lessons from you. Good work !!0 -
Thanks! I let the pros do the hard stuff. I just did the plates, manifold, and ran the tubing for that one zone (so far).
Chris.0 -
pex
What kind of pex is that you used?
pex
The zone pictured, as well as the other extruded plate zone, use Mr. Pex 1/2" with an oxygen barrier for the loops and 3/4" Mr. Pex for the supply and return. The Roth panels, not yet installed, will use 3/8" pex-al-pex.
Chris.0 -
Nice!
Nice piping! All you need is some pipe insulation around the "near boiler" piping...
pipe insulation
Thanks for the tip. Should I insulate right up to the panel? Should I do the same with the pex? And is it OK to use the pipe insulation you get at Lowes or Home Depot on pex (just curious because I think it's a petroleum product)?
Chris.0 -
I use
ImcoLok or Armaflex. It comes in 6 ft lengths with either 1/2" wall or 3/4" wall. It is split down the middle with a sealing tape for ease of install. We miter the corners with a plastic miter box and serrated bread knife. We insulate all of the piping, except the CW feeder.
It's hard tto find the good stuff at the big box stores.
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 109 Geothermal
- 988 Plumbing
- 389 Solar
