Prestige, any problems seen
tim smith
tim smith Member Posts: 2,928
Just checking with all to see if any problems have been cropping up with the Prestige Solo boilers. I have 2 going in next week and just keeping aprised. Thanks, Tim.
  • Supply House Rick
    Supply House Rick Member Posts: 1,399
    As a Supplier
    maybe 70 have been sold, no complaints yet
  • Mark Hunt
    Mark Hunt Member Posts: 4,908
    As a contractor
    no mechanical issues at all with the Prestige.
    Some install tips:
    Make your piping connections to the unit BEFORE you hang it. Tough getting wrenches in afterwards.
    I recommend SJO wire for the high voltage wiring(if code allows)Solid wire is a PITA on any of the Euro boilers
    If I think of any others, I'll post 'em.
    Mark H
  • tim smith
    wiring
    Mark, we only use stranded on all our control wiring. Makes life much easier and tidy. Lots of crimp fork connectors. I like the Prestige and this is our 2nd and 3rd one of this mfr. Thanks for the input, Tim
  • Boilerpro_5
    Boilerpro_5 Member Posts: 407
    Just one 05 code
    which went away when the control was reset. I just found this out a few days ago and am waiting for any detailed info on this from Triangle. Otherwise the 6 I have in are working great. I just wish the piping would arrive straighter on the units...sometimes its more than a little cocked, but is typically easily straightened. I really think we have a workhorse here....something more abuse resistant than the other options out there and with a long life.... The "New Cast Iron boiler".
    Boilerpro
  • hr
    hr Member Posts: 6,106
    Nice
    be sure to use two wrenches when screwing on to the connections. Very soft copper due to the silver soldered connections inside.
    On the small ones I cut off the threaded adapters and solder on my connection. On the 175 I use the B&G threaded iso valve flange to make my first connection. With the handle removed it just screws on to the threaded connections. Gives up a shut off and a good starting point for piping.
    I'm not real impressed with the quality of the piping workmandship inside the boiler, but it works.
    Weil used steel pipe inside the Ultras. A bit neater and more solid to build from.
    hot rod
  • tim smith
    Thanks for the replies guy's. Tim
