Washing boilers
I assume you can not use a soot vac for the wet stuff or can you? What do you just take pump (bug spray) tank fill with green soap and water, and then spray it down? Got that now what do you clean up the sooty water with, newspaper or a regular wet vac, I thought soot was bad for wet vac.Do tell inquiring minds want to know. Thanks you guys are the best. I love some good oil talk, does anyone write a oil burner clean and service book?
