Combi core
Perry_3
Perry_3 Member Posts: 498
Rich:
I had a Vitocell 300 (with SS tank and coil) installed a year ago and no one ever mentioned a double wall requirment.
Does the double tube requirment only apply to steel tubing that could corrode?
Perry
  • bigwilly104
    bigwilly104 Member Posts: 50
    Bradford white
    Makes a combi core line of water heaters. Both inderect and standerd tank type water heater with a coil. I have used the inderects and been happy with them. The supplier stoped stocking them. They said they had a lot of problems with heat exchanger failure. that was five years ago. I would love to use one for a job I looked at today. anyone using these?
    hot_rod Member Posts: 26,645
    The new Combi 2
    is what you want to use. It now has an 1-1/2" steel coil instead of that al/pex coil of years ago.
    Same for their new indirect tank. It also uses that large diameter enamaled steel HX coil.
    hot rod
  • Rich Kontny_5
    Rich Kontny_5 Member Posts: 116
    Double Wall HX ?
    > ago.
    > coil.
    > hot rod
    Is this considered a double wall heat exchanger? Wisconsin is funny about this!
    Rich
  • Rich Kontny_5
    Double Wall HX ?
    Rich
  • Larry (from OSHA)
    Larry (from OSHA) Member Posts: 742
    yes it is
    I have been field testing the powerstor2 for about 2 years now and it has the same HX in it. The link is to the new product info page.
    http://www.bradfordwhite.com/images/hotbox/blitz06/BWC_BLITZProducts06.pdf
    Larry
