Combi core
Perry_3
Member Posts: 498
Rich:
I had a Vitocell 300 (with SS tank and coil) installed a year ago and no one ever mentioned a double wall requirment.
Does the double tube requirment only apply to steel tubing that could corrode?
Perry
Perry
Bradford white
Makes a combi core line of water heaters. Both inderect and standerd tank type water heater with a coil. I have used the inderects and been happy with them. The supplier stoped stocking them. They said they had a lot of problems with heat exchanger failure. that was five years ago. I would love to use one for a job I looked at today. anyone using these?0 -
The new Combi 2
is what you want to use. It now has an 1-1/2" steel coil instead of that al/pex coil of years ago.
Same for their new indirect tank. It also uses that large diameter enamaled steel HX coil.
hot rodBob "hot rod" Rohr
Living the hydronic dream0 -
Double Wall HX ?
> ago.
> coil.
> hot rod
Is this considered a double wall heat exchanger? Wisconsin is funny about this!
Rich0 -
Double Wall HX ?
Rich0 -
yes it is
I have been field testing the powerstor2 for about 2 years now and it has the same HX in it. The link is to the new product info page.
http://www.bradfordwhite.com/images/hotbox/blitz06/BWC_BLITZProducts06.pdf
Larry0
- 87.5K THE MAIN WALL
- 123 Chimneys & Flues
- 118 Geothermal
- 15.9K Strictly Steam
- 57 Water Quality
