Manifolds
Any manifold similar to Caleffi (pairs built to hang with offset) with simple shut-offs instead of balancing valves?
    hot_rod Member Posts: 26,619
    Oventrop and watts Radiant
    had some simple manifolds with just ball valves. Do you need one? How many ports?
    What about copper?
    hot rod
  • Need two pairs:
    1 x 7 port
    1 x 11 port
    3/4" or 1" main; 1/2" outlets
    Prefer 2" o.c. connections.
    Copper is fine. Mains will be copper; branches 1/2" pex.
    Really like the way the Caleffi manifolds are staggered pairs on a good hanging assembly.
  • Watts Radiant looks like it will be perfect. Thanks Hot Rod!
  • Royboy
    Royboy Member Posts: 223
    I confess
    to still making up most of my own manifolds out of copper T's, little lengths of tubing, ball valves, and sweat pex adapters. once a cheapskate ...
    but the price of parts and the tedium of doing this has me wondering about manufactured alternatives. are the Watts & Oventrop ones recommended? does anyone have any experience with Sioux Chief? they seem to have a pretty diverse set of manifold configurations ...
    Roy
  • John F
    John F Member Posts: 29
    Copper Manifolds
    Check out Precision Hydronic Products (www.phpinc.us) also. We manufacture copper manifolds in various sizes, with various drop configurations and fittings. We can also do custom work up to 6-inch pipe diameter. All products are pressure-tested and come with a 3-year leak-free warranty.
