Pex vs copper heat exchanger
hr
Member Posts: 6,106
is a better conductor.
Gosh for that small amount I think I would stick with copper. If it is open maybe stainless or galv?
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
hot rod
Open Storage Tank usingPex coils rather than copper coils
I have a customer with a 900 gallon storage tank, which typically uses two (3/4 inch)180 foot copper coils as a heat exchanger, to heat up the water in the tank. The customer wanted to know whether we could use pex instead of copper to keep the cost down. Can anyone tell me what the heat transfer of pex is compared to copper? The copper coils are approximately two feet in diameter and four feet high and sit vertically in the tank. Thanks0 -
it's less, and I don't think you'll find most PEX manufacturers are excited about submerging PEX. At least some brands can delaminate the layers in the pipe if submerged for long periods.
Maybe not all, but personally I wouldn't do it.0 -
Thanks for the good advice..
I'll stay with the copper.0
- 87K THE MAIN WALL
- 116 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
