oil tank
They are insured and will make sure all EPA guidlines are followed.
Worth every penny!
Worth every penny!
oi tank
what is best way to pump out empty and remove a oil tank from basement0 -
MOST IMPORTANT
Make sure the fill and vent pipe are removed. If unable, then fill them with cement. Too many times, a house that had the tank - but not the pipes removed, someone delivers to the wrong address, and you are the one left with a surprise in the basement. You do not want to be the one this happens to.0
