Teledyne Laars - mini therm JV - reliability
Jerry_15
Member Posts: 379
Life is too short.
Teledyne Laars Mini Therm JV
hi,
Just wondered if anyone had experience isues with this model and brand of boiler.
Thanks,
Tara
Laars JV series
> hi,
> Thanks, Tara
Laars
Very sensitive to proper flow rates & must be set up properly - gas input/type etc. Needs a pro.0 -
Mine had many piping problems, lasted 20 years. Otherwise reliable. Ended up with hole in copper fin tube.
TimJust a guy running some pipes.0 -
laars
I have installed a lot of them; they are a pretty good value (about as cheap as anything out there) and can be pretty economical to operate when applied properly. They can, however, get corrosion in the fins of the heat exchanger which must cleaned out to keep them working properly. Proper set-up and maintenance is important.0 -
not a bad...
little boiler for the money, I had one in my 1st house. it has its place.kpc
- 167 Indoor-Air Quality
