Teledyne Laars - mini therm JV - reliability
Jerry_15
Jerry_15 Member Posts: 379
Life is too short.
  • Tara
    Tara Member Posts: 21
    Teledyne Laars Mini Therm JV
    hi,
    Just wondered if anyone had experience isues with this model and brand of boiler.
    Thanks,
    Tara
  • Ed_26
    Ed_26 Member Posts: 284
    Laars JV series
    > hi,
    > Thanks, Tara
  • Ed_26
    Laars
    Very sensitive to proper flow rates & must be set up properly - gas input/type etc. Needs a pro.
  • Timco
    Timco Member Posts: 3,040
    Mine had many piping problems, lasted 20 years. Otherwise reliable. Ended up with hole in copper fin tube.
    Tim
  • Plumdog_2
    Plumdog_2 Member Posts: 873
    laars
    I have installed a lot of them; they are a pretty good value (about as cheap as anything out there) and can be pretty economical to operate when applied properly. They can, however, get corrosion in the fins of the heat exchanger which must cleaned out to keep them working properly. Proper set-up and maintenance is important.
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    not a bad...
    little boiler for the money, I had one in my 1st house. it has its place.kpc
