Where can I buy old cast iron radiator valve handles?
Jim Bennett
Jim Bennett Member Posts: 607
they are Trane packless bellows valves :-)
The dead men thought of everything.
  • old radiator
    old radiator Member Posts: 3
    Old cast iron radiator valve handles
    Where can I buy radiator valve handles (only the handle) for my cast iron radiators?
  • Brad White_129
    Brad White_129 Member Posts: 15
    The one's I have
    are Bakelite... Capitol is the brand name from 1922... are you restoring them or just need operation?
  • old radiator
    I had the radiators painted and the painter misplaced the handles. I need the handles to control the flow.
  • ed wallace
    ed wallace Member Posts: 1,612
    rad valve handles
    any good heating supply house would have replacement handles
  • old radiator
    Thank you.
  • Brad White_129
    But remember....
    Radiator valves are two-position, fully closed or fully open. They are not meant to "throttle" to control the flow as I think you are suggesting. The packing will start to leak in short order if you do...
  • Brad White_129
    Good Point!
    Never ran across those but it makes sense, abundant sense. An exception to be sure and it underscores avoiding "absolutes" or at least qualifying them. Thanks, Jim.
    Brad
