valve packing
FredR
FredR Member Posts: 62
Could someone please explain-
single cut die formed packing,
double cut die formed packing.
Thanks
  • frank_25
    frank_25 Member Posts: 202
    Where did ya...
    ...find out 'bout that? That happens to be an ultra super secret NASA BuRock spec. for use in the activation of the de-compression activitor prior to initilazing the stepped-up hydrolic booster which enabales the vacuum sensitive micro switch to allow a good flush out the dump port into outter space.
    Here on earth, good ole round on a spool graphite packing usually works well. Comes in various diameters also.
