valve packing
FredR
Member Posts: 62
Could someone please explain-
single cut die formed packing,
double cut die formed packing.
Where did ya...
...find out 'bout that? That happens to be an ultra super secret NASA BuRock spec. for use in the activation of the de-compression activitor prior to initilazing the stepped-up hydrolic booster which enabales the vacuum sensitive micro switch to allow a good flush out the dump port into outter space.
Here on earth, good ole round on a spool graphite packing usually works well. Comes in various diameters also.0
- 86.9K THE MAIN WALL
- 57 Biomass
- 110 Chimneys & Flues
- 5.7K Gas Heating
- 106 Geothermal
- 70 Pipe Deterioration
- 978 Plumbing
- 6.3K Radiant Heating
- 387 Solar
- 15.4K Strictly Steam
- 44 Industry Classes
