Heating system activated by phone
ALH_4
Member Posts: 1,790
Are you looking for a device that works like a cell phone that will turn a switch on and off to the boiler?
You may want a standard phone dialer, and I believe most cell providers have little black boxes that are basically a stationary cell phone. (I know Verizon does) It does require a separate dedicated cell phone line. I havent seen this done with heating systems, but I know Multitrode sewage lift station controls do this.
I have a client that wants to turn his radiant system on at his cottage by cell phone before he arrives. This is a supplemental heat which will be stapled up to sub floor to warm the tile. I planned on using a sensor under the sub floor and a Tekmar set point control. What type of telephone control will work with this? Or is there a better way? I am not looking for temperature adjustment, just on and off feature. Thanks, Jim0 -
Temperature Guard Plus
Jim, I specified one of these about 5 years ago for a client with a ski home. You can get info about it at www.temperatureguard.com/vm501.htm. It will control up to 4 zones.0 -
Remote
This is easy if you use a Viessmann boiler or you could use the Honeywell TAM thermostat system which is also pretty easy and you can not only turn it on you can see how warm it is adjust temp etc. Install it for free with a monthly monitoring fee of say 39.99 locked in for 5.
Sensaphone Cottage Sitter
Cottage Sitter. Look up Sensaphone on the web. Some models have controllable outputs for that purpose (connecting thermostats, etc.)
You can also call the unit and have a temperature report done by a synthesized voice. It will also call you when the power fails or at set low temperature alarms.
Pete0 -
Sensaphone model 400 will answer your call in synthesized voice and allow you to turn on or off the heat, a/c or whatever. I've installed several. They're great. I get them from Graybar.0 -
Honeywell's Telephone Access Module
works with either the Networked Zoning system or the VisionPro IAQ model T'stat. 2 or 4 channel options.0 -
try this
http://www.ecrinternational.com/secure/upload/document/1181.pdf
I have used the temp guard (base model without remote access) with great sucess in cottages.
Mitch0 -
sensaphone....we have a half dozen. they're great.0 -
Phone activated controls
Consider using the new tekmar 538 thermostat, a 079 slab sensor, and a 480 user switch. The user switch allows you to change from Day to Night and to Away temperature settings. The user switch can connect to a FreezeAlarm or possibly a Sensaphone (have not checked a Sensaphone). The FreezeAlarm or Sensaphone in turn connects to a telephone line.
The new 538 is on the tekmar website: www.tekmarcontrols.com
Jay0
