Steam Boiler Recommendations
Steamhead (in transit)
Member Posts: 6,688
is the most efficient I know of. It's a wet-base boiler with a power gas burner, that can also burn oil. Its thermal efficiency is roughly 6% better than the usual atmospheric boiler.
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=367&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Efficient Oil Steam Boiler
After going a year or two without installing any steam boilers I know have two definite installs and maybe one more, they are all residential units requiring between 350 - 500 Sq ft of steam. About 6 months ago a saw some literature on the Burnham Megasteam and I guess they also have a piping kit for it. I ran into one guy who said it's the only boiler he will use for steam from now on. Just looking for some constructive input.
Thanks,0 -
Everyone I respect regarding steam
gives the Burnham Megasteam high marks. It is oil-fired only, so be it, but if I had only oil available and a steam system of course, this is the boiler I would use.
It comes in EDR ratings of 288, 396, 513 and 629 so seems to fit your applications pretty well.
This is a "made for the purpose" steamer, I was told. Not a boiler which can be converted or to serve several applications. It is also relatively easy to clean and is 3-pass, not unlike larger commercial boilers.
I have seen one installed as a replacement (only so many steam jobs out there) and properly piped as it is, very quiet and fast.0 -
What about gas?
What are the options if you only have gas available?0 -
No Natural Gas
There is no gas available on the job.0 -
Smith
Would you use the Smith oil over the Burnham Megasteam? If so, Why0 -
On oil
and if no gas is available, the MegaSteam is the best. But on gas or if the owner might want to switch the boiler between fuels, the Smith is the unit of choice.
The reason is, Smith offers the 8 series with the gas burner from the factory. Burnham does not offer one in the MegaSteam, though they know we want it. If the factory doesn't offer or support it, it's not a good idea to field-engineer this. It might void the warranty.
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.6K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
