Where can I find a tool like this?
ALH_4
ALH_4 Member Posts: 1,790
I'm not entirely sure I understand what you're doing, but I would buy a cheap (maybe not too cheap) 6-point deep socket and take an angle grinder and grind my own slot. It would probably cost less even if you have to buy a cheap angle grinder.
  • Charles_8
    Charles_8 Member Posts: 74
    For fittings with tubing already attached
    Although the condensation (when first filled) caused most of the moisture at the tank bottom, I suspect there is still a tiny seepage from the bottom fitting on my hot water tank. I know I didn't get it tight enough.
    I'm looking for a socket wrench tool like this, but more heavy duty, so I can tighten the 3/4" NPT fitting (1" hex) with the 1/2" copper tubing still attached (and then use a sharkbite coupling to reconnect so I won't have to drain the 40 gallon tank).
    http://i9.tinypic.com/4xnnc4x.jpg
    There isn't room for a crowfoot, so it has to be some kind of deep socket, open to the side... What is the correct name, so at least tool suppliers will know what I'm looking for?
    thanks
    Charles
  • bob young
    bob young Member Posts: 2,177
    try a showerbody type long socket
  • ralman
    ralman Member Posts: 231
    Socket
    Andrews' idea works. I had some sockets made up at a machine shop. A deep well socket with a slot, then cut in half with a piece of pipe with a matching slot welded between the drive end and the socket end to make it about 8 inches long.
  • Lyle C
    Lyle C Member Posts: 96
    socket
    I would stop playing around with the male adapter. Remove it and install a 4" or 5" brass nipple . It will be solid enough you can tighten it from the end with a wrench and then use a female ad.
  • Charles_8
    Nipples
    I was thinking of doing that, although there would now be TWO threaded connections with the potential for leaks, instead of just one :)
    Is it OK to use brass fittings in a hot water system? (Local bigbox store, surprisingly, does have 4 inch long, 3/4" pipe nipples in bronze...)
    thanks
    Charles
