flueway condensation
Steve_153
Steve_153 Member Posts: 4
I'm bidding a replacement for a Weil-McLain P368 steam boiler. This unit was installed less than 10 years ago. It has plugged due to condensation no less than 5 times. The unit is fired at full capacity, has great draft, is always set up with instruments, and is in a dry basement. The unit is properly sized for the connected load is piped properly and doesn't surge. There are no signs of leaks in the sections or at the gaskets. The boiler doesn't use excessive water. It almost seems like the iron is porous. Is that possible?
