steam conversion
Al Letellier_9
Al Letellier_9 Member Posts: 929
Too many possibilities, too little information. Valve stems, a missed trap, leaks in the wall. How did you pipe it? What was original configuration? Many variables of two pipe.......Get the pressure as high as you can and listen for the leaks.
  • Jim_140
    Jim_140 Member Posts: 2
    steam conversion
    I am working on a 2 pipe steam conversion to hot water. I can not get the system to pressurize with air and can't find a leak anywhere!!! It is a 70 year old bldg with 3 stories. Any suggestions welcome- Thanks Jim
  • laurence salvatore_2
    laurence salvatore_2 Member Posts: 86
    coversion
    Your first mistake was not leaving it alone put it back to steam and walk away you will lose less money in the end unless you need a sword of Damiclese hanging around to keep the lads busy when its slow.
  • Jim_140
    traps were gutted and capped -no air vents on radiators-boilers are removed and mains capped.cant pressurize any line!!!
  • This is,
    EXACTLY the nightmare Steamhead always speaks-of,, man are you in for fun!
    Dave
  • Glenn Sossin_2
    Glenn Sossin_2 Member Posts: 592
    fill it
    You wanted it handle water, fill it up slowly and look/listen for the water. It will rear its ugly head probably where you least expect it and don't want it.
    How about a smoke bomb ??
  • gerry gill
    gerry gill Member Posts: 3,083
    gwgillplumbingandheating.com
