steam conversion
Al Letellier_9
Member Posts: 929
Too many possibilities, too little information. Valve stems, a missed trap, leaks in the wall. How did you pipe it? What was original configuration? Many variables of two pipe.......Get the pressure as high as you can and listen for the leaks.
steam conversion
I am working on a 2 pipe steam conversion to hot water. I can not get the system to pressurize with air and can't find a leak anywhere!!! It is a 70 year old bldg with 3 stories. Any suggestions welcome- Thanks Jim0 -
coversion
Your first mistake was not leaving it alone put it back to steam and walk away you will lose less money in the end unless you need a sword of Damiclese hanging around to keep the lads busy when its slow.0 -
traps were gutted and capped -no air vents on radiators-boilers are removed and mains capped.cant pressurize any line!!!0 -
This is,
EXACTLY the nightmare Steamhead always speaks-of,, man are you in for fun!
Dave0 -
fill it
You wanted it handle water, fill it up slowly and look/listen for the water. It will rear its ugly head probably where you least expect it and don't want it.
How about a smoke bomb ??0 -
any underground return pipes?
if so they may be leaking.
Serving Cleveland's eastern suburbs from Cleveland Heights down to Cuyahoga Falls.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 68 Pipe Deterioration
- 940 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
