FPS Velocity calculation
Brian_18
Member Posts: 94
Can somebody point me to a chart of velocity for various size pipes, per flow rate? (or give me a formula) I will be pumping 7 gpm through 1" Kitec PAP. I would like to know what the fluid velocity will be, so I can (try to) calculate heat loss (temperature drop) through a proposed underground insulated run. Thanks in advance
Go to
B&G web site and look for Syzer.0 -
Thanks Bob !!
Nice compact little program, exactly what I needed. Life is Good!0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 107 Geothermal
- 983 Plumbing
- 389 Solar
