Older tigerholme tigerloops full of oil
John@Reliable_14
Member Posts: 171
both above and below level. Most of the time you will find a crack in the housing, close to top vent(but no oil will come out). Now if I find one full, just replace it. I have drained them in the past, but they always fill back up, and start making some funky sounds.
Tigerloop loopdeedoop
I have been installing tigerloops for a long time and have begun to notice that the older models are all full of oil in other words there is no air space at the top. I just left one that was humming a first for me. I am able to free up the mechinism and I have not noticed it with the newer tigerloops or with the tigerloop ultras. Has any one out there come across this and is there a remedy0 -
Is the Tigerloop above or below the level of the oil?0 -
According to their literature if the chamber completely fills install an OSV in the suction line.
I called Westwood Products a few years ago because I had replaced several Tiger Loops due to a whine that developed. I was told that the problem was job specific and was probably an interaction between the internal check valve and the pump's gearset.
I installed one of them on my own burner about 7 or 8 years ago and it's been quiet. Likewise, the TL I installed on the other job as a replacement has been quiet.0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
