Taco zone fails to open?
Rely_2
Member Posts: 61
Taco gold zone valve has to be powered down before you manualy purge through the valve,did you shut power off to boiler before opening valve if not it is possible to cook the thermostat.What kind of stat do you have
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=342&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
In the past week I have seen two Taco Gold zone valves with what I think is the same problem. If the valve is opened manualy I can purge the zone and get hot water from the return. When I stop purging with the valve still manualy open the flow seems to stop.
Any ideas?
Thanks0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 946 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
