Ever used a TV?
Boilerpro_5
Member Posts: 407
on the cast iron boilers I put in. They work well, I have found the 1 inch doesnt' seem to work well on anything but the smallest boilers, even though its flow rating is higher. I am using them less now that I am putting in the Prestiges in many systems.
Boilerpo
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=393&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
Boilerpo
I chose a ESBE (Danfoss) Thremic valve (TV) as my boiler protection on this job. I installed it on the return. Any opinions on this? Comes preset for 140 ret temp, or 160 if installed on the supply.
TimJust a guy running some pipes.0 -
Thermic Valves
We use them as well with great success. They are pretty slick when you think about it.0 -
Where do you buy them, my suppliers give me the "Deer in the Headlights" look when I asked.0 -
ESBE Danfoss
Any of your suppliers should have access to them. They would all benefit from stocking some.
What state are you in and who do you buy from?0 -
I bought mine at Lundquist here in Salt Lake...
Sid Harvey and Blackmann and a few others. I'm on Long Island NY.0
- 167 Indoor-Air Quality
