concord furnace combustion chamber replacement
B. Tice
B. Tice Member Posts: 206
This is the same as Armstrong, Ducane, Lennox. No, they are not successfully replaceable. Armstrong would like to see you replace the heat exchanger instead. Not too bad of a job on these.
  • charlie_15
    charlie_15 Member Posts: 6
    chamber replacement on concord oil fired funace?
    hi folks,
    is this possible to do? and how would you go about doing this?
  • Ken_40
    Ken_40 Member Posts: 1,310
    Concord?
    Unfamiliar with the brand. Are you sure its a furnace, not a boiler?
    Typically, when the chamber goes bad, the rest of a furnace is also near death. If this is not the case, perhaps a search for the manuacturer and replacement parts might show an exploded view, suggesting what may be involved in the repair?
    If it is a boiler, many makers of "one-size-fits-all" chambers are viable.
  • joel_19
    joel_19 Member Posts: 933
    concord
    Most any oil furnace can have it's chamber replaced . There is a fiber type material that forms a chamber inside the combustion heat exchanger. The fiber can fail and that can then dammage the heat exchanger itself. Those are not our favorite furnace we would probably elect to replace the entire furace.
  • John Mills_5
    John Mills_5 Member Posts: 952
    Concord is
    just an Armstrong/Lennox unit. We've never had to do it since they are so new. But now that the oil guys know what it is, they can tell you better.
