Job Pics (The Youngster)
Josh_10
Josh_10 Member Posts: 786
Gary the primary feeds the secs in parralel. I also did a reverse return with the primary.
So I guess the piping method would be described as parralel primary secondary tertiary reverse return.
This sytem is made for perfect balance.
  • Josh_10
    Okay I don't like to show off too much but I had to cram alot into a tight space. She isn't wired yet but here is a teaser. Also the expansion tank is hidden behind the wall.
  • Ray Landry_3
    Ray Landry_3 Member Posts: 94
    Nice!
    Josh that is one sweet looking install! A piece of art like that should have it's own room, not closet! Pics aren't the best quality though, it's tough to see your piping strategy. What are the heat emmiters?
  • That is Awesome !
    You do some amazing work Josh . Don't ever be shy to post your work here . I don't think it's showing off . It's more of a pride thing .
  • Brad White_145
    Brad White_145 Member Posts: 17
    What a beautiful thing!
    Josh, once again, you set a high standard. Incredible and inspiring.
    I want to solder like you when I grow up.
  • ALH_4
    ALH_4 Member Posts: 1,790
    Beautiful
    Is that aluminum sheet on the wall? Do you do anything to create that finish? I like the Tekmar controls in the enclosure.
    -Andrew
  • David Sutton_6
    David Sutton_6 Member Posts: 1,079
    Sweet !!
    Thats some fine craftsmenship!!!! keep it coming, helps to the rest of us trin harder!!
    Very nice work Josh !!
    David
  • Josh_10
    Andrew, the background is stainless steel. We do a few things for the finish on both stainless and the copper pipe but that is a family recipe that I can't give out. It does last though. The pipe will retain it's shine for years.
  • Ted_9
    Ted_9 Member Posts: 1,718
  • Jamie_6
    Jamie_6 Member Posts: 710
    Great looking job Josh! How do you like the Tech-net 4 stuff?
  • Christian Egli_2
    Christian Egli_2 Member Posts: 812
    Such things need their own web cam 24/7
    Looks like the fancy innards of the bionic man, and stainless steel no less, it'll be indestructible.
    Very neat, Josh, thanks for sharing the pleasure.
  • joel_19
    joel_19 Member Posts: 933
    Grrrrr
    That looks nice there youngster very impressive. quit doing that or you'll make us old guys have to work harder and we're to old for that.
  • Andy_14
    Andy_14 Member Posts: 121
    Very nice work! I have to say...I've seen more people who take pride in their work on "the wall" than i've seen in the last 20 years anywhere. All of you who strive for perfection like this should be very proud! Thanks for the pics!
  • heatboy
    heatboy Member Posts: 1,468
    I have never seen.....
    .......a project look more beatuiful! Did you make money?
  • Now THAT is a compliment...
    Josh, you probably don't know hb from Adam, but let me tell you, you have just received the ultimate compliment from what I and others consider the Master of Hydronic Beauty.
    Great job. Show case for sure.
    Not to try an take away from your galleria, but here's an example of hb's work.
    I too hope you make money:-)
    There is the labor of love, but it don't pay the bills.
    ME
  • Josh_10
    My gosh thanks for the great compliments guys. HB I will treasure the compliment. Coming from you that is worth remembering.
    As for making money yes we did. This project took about 7 weeks to complete. We had two air handlers with returns in every room, humidifiers, de-humidifiers, 18 seer heat pumps, and sup-pure air purifiers. In addition we had a Rehau sprinkler system, 3 44" propane fireplaces, and patio heaters.
    Not shown are two Superstor Ultra 80's for the 19 GPM shower.
  • Josh_10
    Jamie I really the the Net4 system. It allows the kind of control a home "should" have. I have quite a few Net4 installations out there and not one problem.
  • John Ruhnke
    John Ruhnke Member Posts: 1,020
    I am the walking Deadman
    Hydronics Designer
    Hydronics is the most comfortable and energy efficient HVAC system.
  • John Ruhnke
    Real nice!!
    Heatboy,
    A real work of art!!
    You and Josh should be very proud you both do top notch work!!
    JR
    Hydronics Designer
  • Wayco Wayne_2
    Wayco Wayne_2 Member Posts: 2,479
    Josh
    As Frank Zappa would say, "Great googely moogely!" Looks fantastic. Don't be shy about sharing. We likey. WW
  • Jamie_6
    We have a few in also! The only problem I have with them is I think the t-stats are not to homeowner friendly!
  • Mark Wolff_2
    Mark Wolff_2 Member Posts: 76
    Alaska
    If you ever feel like moving to Alaska, you'd have a job with me. Great job on the layout and execution.
  • Mike T., Swampeast MO
    Mike T., Swampeast MO Member Posts: 6,928
    Oh my! Your level of craftsmanship is truly exceptional. You're not bragging--you're showing what is possible.
    A few months ago you asked for a critique of your new website. It was filled with superlatives. I recall saying something along the line of, "no problem with superlatives as long as you deliver".
    If the operation, fuel efficiency and versatility match this craftsmanship then your superlatives are understatments!
  • Tom R.
    Tom R. Member Posts: 138
    Class!
    That's the way they fit pipe in Heaven.
  • Constantin
    Constantin Member Posts: 3,796
    Beautiful...
    That's some really tight work in a very small space. Neat too!
    Is there a reason the (TN4?) controllers are behind a locked panel? Are you guys worried about little hands changing the reset curve? :-P
  • Anthony Praga
    Anthony Praga Member Posts: 74
    very nice
    that looks unbelivable! great job!
  • Singh_2
    Singh_2 Member Posts: 20
    Brilliant
    Gorgeous , stunning, pristine, exquisite, does not even begin to
    describe that installation Josh.
    Has Joe K. from Buderus seen this?
  • Josh_10
    No I don't think he has. I need to talk to him anyway. Mabe he'll see this thread.
  • GW
    GW Member Posts: 5,137
    where
    is the pic looking straight on? I'd like to see how the pri feeds the secs
    Gary Wilson
    Wilson Services, Inc
    Northampton, MA
    gary@wilsonph.com
  • heatboy
    Just love what I do..............
    ..........as long as I am making my margins. The starving artist thing isn't for me! It doesn't matter how cool the job is. If the money is not there "These boots are made for walking".
    Thanks for the very kind (and humbling) words, ME.
    Amazing work like I see from Josh makes up for all of the .......well, let's just say substandard work I see everyday.
    hb
  • Weezbo
    Weezbo Member Posts: 6,231
    *~/:) You are all over it Ladd:)
    Tight:)
    when one is single minded then one accomplishes his duties'''
    that work is truly exemplary.
  • DanHolohan
    DanHolohan Member, Moderator, Administrator Posts: 16,687
    Josh,
    why don't you folks take a Find a Professional ad so that the thousands of potential clients who visit here each day will be able to find you?
    Retired and loving it.
