Unknown Noise From Boiler Room
Hi All,
Recently I've noticed a new noise coming from my boiler room when my 15 year-old SlantFin gas boiler starts up. The noise is a high pitched buzzing, is present during most of the heating cycle, and is loudest during the overnight runs (3:00-5:00AM). During the rest of the day I don't hear the buzzing.
Oddly enough, the noise seems to be coming from inside the exterior wall of the boiler room and not from the boiler itself.
Any ideas?
Thanks,
Tom
  • gerry gill
    gerry gill Member Posts: 3,083
    is that where
    the transformer is located?
    gwgillplumbingandheating.com
  • Big Ed
    Big Ed Member Posts: 1,117
    Buzzing
    Sounds like a wall relay or transformer on it way out. Sometimes you can get lucky and find a loose cover or maybe it's pipe vibration you can cushing. You need to find the source.
    It's normal to hear it at early AM. The heat is the only thing running at that hour.....
  • Plumdog
    Plumdog Member Posts: 18
    Do you have natural gas or LP by chance? Next time the noise starts go and listen to the regulator (next to the gas meter or gas service line) and see if it starts there.
  • jbplumber
    jbplumber Member Posts: 89
    Garlic
    consider placing a paper bag containing garlic above the doorway--should keep the spirts at bay.
  • Sweet_2
    Sweet_2 Member Posts: 143
    Dont forget to
    keep the horse shoe facing up. Is it possible you have a bank of telestats in that wall with LED boards powered by transformer.
  • Weezbo
    Weezbo Member Posts: 6,231
    Transformer...... really really likelihood.
  • LEAD PIPE
    LEAD PIPE Member Posts: 199
    Noise
    sounds like spooks
  • Geno_15
    Geno_15 Member Posts: 158
    It'ssss.....
    ....THE BOOGY MAN!!!!!!!!!!
  • jim sokolovic
    jim sokolovic Member Posts: 439
    Maybe a switching relay...
    for a zone that only calls for heat around that time? Are there different zones with setback thermostats that could create this scenerio?
