nat. gas steam boiler with tankless?
American plumber_3
Member Posts: 3
Does anyone know of a natural gas steam boiler that also has a tankless coil built in for domestic hot water. have a oil fired steam boiler with a tankless coil that needs to be replaced but cust wants to convert to gas. it's in a tight space. my heating supplier said they don't carry any. only oil fired with tankless. Is there some reason why they don't do tankless coils with nat gas?
Peerless used to make
a steam / hot water boiler with a coil port . I believe it's now their " 63 " series . I'm not sure if it's still an option with that brand .
We used that boiler with a coil once in a tight spot . Worked pretty well for hot water - one bathroom home though .0 -
I checked out the peerless 63
It doesn't show an option for a tankless coil. I did find that slant fin makes one called the galaxy that is nat gas steam with a tankless. I wonder why burnham or weil mclain don't make one0 -
weil mclain
makes the EG series. Water or steam with optional tankless0 -
conversion burner....
w/ a MPO or a SMITH 8 series...0 -
Peerless hot water
I believe Peerless still makes the PARTNER hot water storage tank for the 63 series. You may want to check it out.0 -
Weil Mclain
Does but it is typically special order. You can also install an oil boiler with a conversion burner.
Why would you want a tank-less?
> nat gas?
